Radiator Removal
Radiator Removal
I am new to the forums and I did not see a post yet about radiator replacement. I have a 1999 93 turbo and I am almost finished replacing the radiator. I am having some problems getting the actual radiator out. I have the fan shroud off. The A/C is unbolted and all the hoses are disconnected. Radiator still won't budge on the driver side. Any help would be much appreciated. Thanks, Josh
RE: Radiator Removal
hi hope this helps
Removal and Installation Instructions for Saab 900-93 Radiators
STEP1
Remove the Intercooler
STEP2
Remove the grille
STEP3
Remove the oil cooler (certain cars) and hang it so the hoses are not bent
STEP4
Remove the AC condenser from the radiator
STEP5
Disconnect and remove the battery
STEP6
Drain the coolant. Remove the lid on the expansion tank to speed up the draining
STEP7
Remove the bypass hose together with the intake hose on Turbo Cars
STEP8
Remove the upper radiator hoses from the radiator
STEP9
Remove the radiator fan's electrical connections
STEP10
Remove the servo pump's oil pipe and the Radiator breather hose clips & turn oil hose to one side
STEP11
Remove the 2 screws on the fan Shroud
STEP12
Remove the transmission oil pipes by the oil cooler & the screw holding pipe to radiator
STEP13
Remove the lower radiator hose, remove clamps which hold the radiator to cross member and pull up the radiator from the rubber mountings so that the clip for the A/C compressor's cable can be undone.
STEP14
Lift out the radiator. Refit in Reverse
STEP1
STEP2
Remove the grille
STEP3
STEP4
STEP5
STEP6
STEP7
STEP8
STEP9
STEP10
STEP11
STEP12
STEP13
STEP14
